N-Gage playlists & Mac?
2 replies · 2,153 views · Started 18 February 2005
Anyone know how to generate N-Gage-compatible playlists with a Mac? Ideally, I'd like to be able to convert iTunes playlists to N-Gage-compatible ones.
I finally upgraded from a 64Mb MMC to a 1Gb one, & want to be able to put several of my albums on my N-Gage without having to just play through them all unsorted into the Sounds/Simple folder. I had a quick search through the forums, & didn't find anything on this.
Thanks in advance, as always! 😊
Thanks for the tip. OK, I've found & run this:
http://www.jeffiel.com/software/playlist/
to get myself m3u versions of my iTunes playlists, and then copied the playlists & music files (along with a corresponding directory tree) to the Sounds\Simple folder on the memory card, but it's still not picking up the playlists & using them. They only show up as text notes under FExplorer as well, so I can't make it play the lists from there, either.
Hm.
Any chance someone could tell me whereabouts the music files & playlists need to be placed on the MMC, &/or maybe post a sample couple of lines from inside one of the playlists, so I can check that everything's pointing to the right place? I'd like to make sure of the file path specifications within the .m3u files...
