i only have a card reader and i like to use pc suit
but the only thing i read is that you must use bluetooth or a connection cable with my nokia n-gage qd
(i have no cable and no bluetooth)
can i use pc suite only with a card reader?
robzy999 wrote:i only have a card reader and i like to use pc suit
PCsuit works ONLY via USB. You can't run it using a carde reader. Qd has no cable, only the NGage classic has. But the PCSuit will not work there either with a cable.
so there is no use for me at al meaning pc suite
askr wrote:PCsuit works ONLY via USB.PC Suite for the N-Gage works ONLY via Bluetooth (it does not work via the N-Gage USB connection at all, because the USB connection with the N-Gage only allows access of the memory card from a PC).
