nokia 6600 and tomtom install probs
9 replies · 9,170 views · Started 18 February 2005
can anyone help im pulling my hair out trying to install tomtom on my mobile
all files go across blutooth no probs but when i go to the exe file to start program a message come up saying files are not supported helpppppp pleeease 😮
Don't you just take the mmc out of the tomtom box you bought it in and insert it into your phone? I thought it all ready came installed on the card?
There will be some files in the tomtom directory on the MMC. You need to make sure that these files are not read only, if they are then you need to remove the read only property.
You can do this either two ways, either get a program that is a file explorer for you phone (www.gosymbian.com - File Explorer). Or if you have a mmc card reader you can use that to remove the read only.
Hope this helps
Diasmj
i've the same problem. have u managed 2 sort this out?
maz wrote:can anyone help im pulling my hair out trying to install tomtom on my mobile
If you copy over everything from the original mmc as it it is, everything should work just fine, mine did, the app appears on the the menu and if you select it, it runs. Exe files do not work on a symbian phone you shouldn't even be worrying about that file.
lakeywhite wrote:If you copy over everything from the original mmc as it it is, everything should work just fine, mine did, the app appears on the the menu and if you select it, it runs. Exe files do not work on a symbian phone you shouldn't even be worrying about that file.
I did what you suggested. It works fine.
Thank You.
Merve
merve wrote:I did what you suggested. It works fine.
Thank You.
Merve
Hey guys, yeah card reader is the best. Any of you know if i can have tom tom AND route 66 on one mmc?? I have both and want to put them on my 512 mmc which has route 66, but i want to try tom tom without swapping cards.
Are u sure you have the right sofware ? It must be "Tom Tom Mobile 5"
cheers
George
parry4643 wrote:Are u sure you have the right sofware ? It must be "Tom Tom Mobile 5"
cheers
George
It needs to be the software on the mmc in the package you bought, it doesn't matter which version as they all work with the provided gps unit, it is just the more recent ones will have more up to date maps.
i have been having the same problem as well.
I copied from cd to formatted, FAT rsmmc and inserted into my N7610. it works up to where i select voice(first installation) and the it shows no map found,.
can u please advice on what to do or do u know anyone who can lend a hand.
I am kinda lost here.
thanx
