installer not installing on nokia 6600
2 replies · 3,038 views · Started 19 February 2005
well i downloaded like a trail for eti camcorder pro and even the philips camcorder and i used a bluetooth dongle to send it to my phone and it sends it and when i try and open it than it says installing... but than it goes back to the inbox and reads as if the text message was never opened oh and by the way where can i find full version of eti camcorder because i tried everything and no one sells it anymore well if you can help me out with this problem id appriate it thanks
Have you left the inbox and looked on the normal menu screen for the install because the message will not delete itself after an install, once complete you will have to delete the inbox message yourself. Or maybe the file you have is corrupt?
lakeywhite wrote:Have you left the inbox and looked on the normal menu screen for the install because the message will not delete itself after an install, once complete you will have to delete the inbox message yourself. Or maybe the file you have is corrupt?
no the install screen pops up but doesnt get installed like it stops before it starts
