Multiple questions about the Nokia 6600...
1 replies · 1,855 views · Started 19 February 2005
Hi all,
I have multiple questions about the Nokia 6600...
1. When i plug my headset into the phone, the following message is displayed: "Enhancement not supported !" It's the Halo 2 headset, and i know it's designed for play on the XBox, but isn't there a way to "install support for different types of headsets" or something like that ? 😊
2. What do you people find the best program to clean up the phone ? I mean like the registry and stuff to keep the phone fast ?
3. Is it possible to install screensavers ?
Thanks in advance !! 😉
1, Erm, you need to plug a mobile phone handsfree headset into the phone, in order for it to work with your mobile phone. There are many manufacturers of these not just Nokia but they need to be made for compatibilty with the model of phone that you want to use them on. There is no installation necessary.
2, There is no registry on the phone, when you unistall programs all files are removed, the contact database recompresses itself at regular intervals if it needs it. If you are worried about memory becoming fragmented, no need to really, but you could back up your phone using PC Suite, do a factory reset (search elsewhere on the forums for this) and then restore the phone from backup.
3, There are some available from the handango shop, click on tab above, I bought a fish one for my friend, but I do not know how to create your own.
