apps can't connect to gprs
1 replies · 1,926 views · Started 19 February 2005
Hi, I have a Nokia 7610 and I can't get 3rd party apps to connect to the intertnet via GPRS,
for example, Opera, MobileMule or NetFront. However the standard built-in Nokia web browser
can connect and i can browse the web.
My firmware is v4.0437.4, but I don't think it's a firmware problem because I had the same
problem before i upgraded the firmware.
I've formatted the phone, resetted and everything. I think there may be a setting somewhere
that I need to tun on.
Also, I only have one access point which works with the default nokia web browser, so this access point should work with other browsers/apps, but it doesn't
Any help will be appreciated
yasin wrote:Hi, I have a Nokia 7610 and I can't get 3rd party apps to connect to the intertnet via GPRS,
It is not neccesarily tru that one access point will work for the Nokia browser and other apps. You will need a certain Internet access access point for Opera and Netfront. Probably this is not set up correctly on your phone.
see this page for access point that Opera will work with:
http://www.opera.com/products/mobile/docs/connect/
