I have been using the OEM 64MB card that I got when I bought my 6630.
I use the 2.xx.xx software (11-11-04) and will upgrade to 3.45.11.3 soon.
TODAY, in the morning, I read a message i got, then left the phone, then after 10 minutes, i tried to open the message again, and POOOOOOOOH!!!
"MMC card cannot be read... I will use the Phone memory to save messages..."
I say, Ok, what the... I will reboot. I rebooted. Nothing new. CARD DOESN'T WORK.
I did NOTHING that could cause a damage, I read a new sms, and then after 10 minutes, I tried to read one, again.
THE RESULT:
* 6630 says there is NO CARD on the phone, although it's in. So I can't even format!
* Nikon Coolpix 2200 says the card is not formated (it could format my old N-gage card successfully when other attempts would fail), but it FAILS to format it!
* Nokia N-Gage says "card is destroyed", but when it's about to start formating it, it stops after half a second!
* Pc card Reader can't recognize the card, nothing is shown, and i CAN'T format it.
It's VERY serious, and the phone is NEW.
DOES ANYONE have any suggestions on that, please?
(I have been searching for a software -like Partition MANAGER 2005- to fix the MBR or something, the Demo version of Partition Manager 2005 CAN see the MMC card, although it can't read it. Though Fix MBR is Not enabled on Demo version. Any other software?)
Please, suggest.
ALSO, make FULL backups of your card. The phone is NEW and VERY WELL KEPT for it's first Week, and it managed to DESTROY MY CARD (i think...). It could happen to Anyone, I guess. :icon13: :icon13: :icon13:
What To Do?... i have data on that card. but EVEN if they get lost... I JUST want to FORMAT the card........
Thank you,
George.
