Is there any apps that can transfer the files u received from bluetooth from the inbox to ur mmc directory instead of need to open it from the inbox?
Bluetooth Inbox Explorer
Forward or the Beta version of Fexplorer
Unplugged wrote:Forward or the Beta version of Fexplorer
Can u post the link of the application which u refer ?
http://www.gosymbian.com
http://www.compsoc.man.ac.uk/~ashley/
Both are Freeware
I using fexplorer beta 1.12. U mean u can see the bluetooth files in the inbox. Then can copy to mmc. I try it with my friends later. Thks.
