pc suit problem
3 replies · 2,679 views · Started 20 February 2005
i have a n-gage qd and the bluetooth on my computer, i can send songs to qd but i dont have enough memory so i want to put it directly on the MMC i already have MsvDrive. i want to use pc suit but when i open pc suit it says connect your n-gage qd to the computer and press ok. i dont know what to do when i open my bluetooth it says N-gage QD serial port not connected so how do i connect it.
With your PC's Bluetooth software you need to create a "virtual" serial (COM) port first (how it is done depends on your PC's Bluetooth software), then you need to use the m-Router/Connection Manager of PC Suite to enable that serial port.
N/A wrote:With your PC's Bluetooth software you need to create a "virtual" serial (COM) port first (how it is done depends on your PC's Bluetooth software), then you need to use the m-Router/Connection Manager of PC Suite to enable that serial port.
if am using USB not serialport? :icon4:
PC Suite will not work with the USB cable with the N-Gage, only Bluetooth (and the N-Gage QD has no USB connectivity at all).
With an USB Bluetooth "dongle" (adapter), it will for the PC and PC Suite emulate a (virtual) serial port.
