The only free messenger I know of that supports ICQ is Quicksilver Messenger which is a Java App, though I havent tried it.
http://www.softex-india.com/downloads.html
I cut it from other forum.
Tried install and play with this appl..... kinda of buggy.. once you login.. you can't exit or close the appl...
Perhaps will be able to see more feature in the next version?
please let me know,how to create an instant messenger.
From,
Kishore Prakash
I found an applikation that works with both ICQ and MSN
it look's like it is free so far
Works for me
Guti wrote:I cut it from other forum.
A JAVA IM won't work on the 7650, because it doesn't support soceket connections (via JAVA) ... you must install an application written in a language supported by the OS itself (C++, etc...) ... try AgileMessenger -- it's the best IM out, free, and pretty freak'n good -- kinda big, but it's good .... (http://www.agilemobile.com/)
Hi all..
I have'nt been able to connect with Agile Messenger after the recent upgrade. Even going back to the older version does'nt seem to be working. I'm on 7650
Any workarounds would be much appreciated
Sanjay
