hi please i need your experties i have a ericsson p900 i wanna do a master reset but forgot the code that i punched in, is their anyway i could master reset it again i have used 0000, 1234, 12345 and still with no success please need your advise
forgot master reset code help me
I have the same problem on my P8. Help pls.
key in this (jog dial up * jog dial down jog dial down * jog dial down *) in the flip closed view., to access the service menu. Then choose the option to format the internal disk.
This formats C, and replaces it with the ex-factory setting.
This wont mess up my phone will it?
Actually a master reset deletes all user data (eg photos, apps), and a format deletes everything on the phone and reinstalls the operating system, so you have a clean phone to restore a backup/reinstall your apps etc.
I have done it a couple of times, it simply returns it to its "out of the box" state. It's slightly more comprehensive than a master reset, but I think better, depending on what you want ot achieve of course.
Anyway, why did you want to do the master reset in the first place?
liverpool lad wrote:Actually a master reset deletes all user data (eg photos, apps), and a format deletes everything on the phone and reinstalls the operating system, so you have a clean phone to restore a backup/reinstall your apps etc.I have done it a couple of times, it simply returns it to its "out of the box" state. It's slightly more comprehensive than a master reset, but I think better, depending on what you want ot achieve of course.
Done the master reset. It worked fine.
It's a second hand phone. I don't know the lock codes. Is there anyway I can get that back to its default code?
liverpool lad wrote:key in this (jog dial up * jog dial down jog dial down * jog dial down *) in the flip closed view., to access the service menu. Then choose the option to format the internal disk.This formats C, and replaces it with the ex-factory setting.
OK, I have this issue as well, someone left our firm, and forgot the Device Lock code. But the solution listed doesnt seem to reset the Device Lock code.
It does just about everything else, but when I try to change the device lock settings, it tells me that the code is incorrect when using the default 0000. This is exactly the same behaviour as before the format.
Any other ideas?
will this efect the free sim or will it go back to the shop bought sim ???
my contacts in p800 corrupted after uninstalling SMS tones. i have backup of contacts & want to do master reset, but forgotten device lock code. wat to do. PLZ HELP, :frown:
