I can't get it to work to send MMS to another nokia 7650.
Probably the settings, but I don't know what to put exactly in.
I tried some settings but failed.
They told me (sim provider) that I only have to put in the SMS centre No. and that's it (+35799700000 - CYPRUS)
Some help please???
Multimedia message help!!!
Have you GPRS? If not, login GPRS whit your operator and after this ask for the multimedia settings.
hadjicostis, MMS only works on GPRS network.
Check with your ISP if your account have that serivce?
You'll need to have your GPRS activated by your mobile operator.
Then save the GPRS settings into your phone, then save the GPRS MMS settings into your phone & set the MMS settings as your MMS's access point.
That should be it.
i think he got the point bout the GPRS 😃 😃
[quote="Pichu"]i think he got the point bout the GPRS 😃 😃[/quote]
Eh.. Who? :P
thanks for the help... I already asked the provider about this... he told me GPRS and MMS are different and that I only needed for the MMS to put my SMS centre. Anyway he wasn't very polite neither helpful and I quited on that. Thanks again I'll see further what I can do
