when 6630 is in standby and it's showing time screensaver, when i put it close to my ear, i hear like Tic Tac..noise..like a little clock..
when i open menu, there is like ultra frequent noise..
and when i call people, i heat that ultra sound to, like the sound of processor..
is this normal?
2PACroatia wrote:when 6630 is in standby and it's showing time screensaver, when i put it close to my ear, i hear like Tic Tac..noise..like a little clock..
when i open menu, there is like ultra frequent noise..and when i call people, i heat that ultra sound to, like the sound of processor..
is this normal?
maybe faulty speaker, get a nokia repair shop to check it out, mine doesnt do that.
Sure its not a dodgy vodafone handset hehe :tongue:
If you listen closely, they all do that.
The high-pitched whine is caused by the screen backlight, and the in-call noises are due to residual RF interference with the speaker.
It's nothing to worry about, as unless you've got the thing pressed up against you the whole time and never leave a quiet room, you won't hear it.
These things can sometimes be voltage or electromagnetic radiation waves effecting the phone's speakers too
okey, whouuuu...
i've changed my handset once, mmc once 2..
i don't wanna do that again..
then, these noises are normal..
true..if u r not in quiet room..u won't hear those..BUZZ sounds during convesation..
and another thing..
is there a way to set alarm, that will GO OFF if phone is switched off, other then Alarm clock ( i.e. for every day in specific time? )
when u set alarm in calendar, it wont go off if phone is off
tnx guys
