Bluetooth Internet Access Settings
1 replies · 2,517 views · Started 21 February 2005
All
Has anyone been able to use the built in SendoX Web browser over a bluetooth connection to a PC ?
If so would it be possible for you to post your settings both on your SendoX and PC.
Sendo X: Access Point Settings....
Sendo X: GRPS Settings...
PC Settings: eg Internet sharing ? ...
If MRouter is running and what it does when your connetion is working ....
What BT profiles you have set up ? eg Serial...
Thanks in advance
Regards
G
GSM wrote:All
Thanks in advance
Regards
G
Yes, I managed to get it to work. Just follow this simple instruction for the Nokia N-Gage http://www.allaboutsymbian.com/forum//forum/thread/26071/&highlight=internet+bluetooth
Works fast as H**L but, after a short time of browsing I get error message that the memory is full. So clearly the Sendo X is not intended for browsing the web over such a fast connection, rather simplified WAP-pages...
BTW! I am using M-router 3 Beta, don't know if the m-router that is embedded in Sendo PC-connect will work in this conetxt. Honestly I doubt because I had severe problems to connect through bluetooth to my pc with it. Had to emerge to 3.0 Beta!
good luck 😊
