Colors and Right panel
5 replies · 2,744 views · Started 22 December 2001
Hi all!
Loony, perhaps you can help me. I made a skin with a dark image for right panel, then the text of toolbar is not visible. I used Colors to change the color of the text of the toolbar, but after rebooting the color didn�t change. It works only if I set the right panel as Plain.
Is it possible to change the color of the text with a customized image for right panel?
Best regards and Merry Christmas to all!
Yeah....I know.. User posted image
It seems like that COLORS is not truely compatable with out custom textures..
It only seems to change the panel text color when you use NO texture..
I have the same problem myself.
It�s in my opinion a thing they SHOULD correct and make a version 1.2 User posted image
Catch me on ICQ or Messenger....
There is also some new issues about the CORRECT size...I made us a very nice WW2 skin and I discovered that our Standard 575*200 ( 462*200 and 113*200) IS TOO BIG User posted image
I had one of my friends(the kind that works with Photoshop on a daily basis) User posted image over to give me a helping hand..And we discovered fistly the faulty resolution but also a trick to use Dithering and Noise on the .BMP to make the colours of the skin unite more evenly..
But more on that later... User posted image
Still busting my brain.....
Cheers, Regards, And best holiday wishes..
Yeah... I use Photoshop too. I�ll try it with the noise! User posted image Anyway I use 577x200 (463 and 114) because I tested that when you set 113 there is one column (1 pixel) that is empty in some views.
Btw, I wonder if you put the skin of Manowar on your page! User posted image
Damn! Then I�ll change my skins about LOTR and will change the right panel image. I�ll send it to you.
Best regards to Northland User posted image
PS Now it�s snowing in Spain User posted image
There is a little file called display.mbm in c\system\data replace that file with one that comes with the skins on Loonyworld's site and then you'll have a customised right panel.
Flipside
Yeah, hear to Flipside.
And if you want a customized (created by yourself) images for your right panel, I think that you could send them to loonyworld. He is a very nice guy, and he could prepare the images for you.
Regards!<font size=-1>[ This Message was edited by Manowar on 2002-01-04 0228 ]</font>
