Need help with Screen Calibration
2 replies · 2,136 views · Started 22 February 2005
The calibration works fine on most of the screen (except for the keyboard icon on the bottom).. It always clicks above of where it should.. So, I intentionally calibrate the bottom right area of the screen to click a bit lower, but this also screws all other icons on the screen.
I tried to calibrate the screen multiple times.. Have also master reset the phone, used the jog dial to set the calibration to default.. None of these work to fix this problem.
Is there are permanent cure ? Can someone help please ?
Thanks !
bms wrote:The calibration works fine on most of the screen (except for the keyboard icon on the bottom).. It always clicks above of where it should.. So, I intentionally calibrate the bottom right area of the screen to click a bit lower, but this also screws all other icons on the screen.
Thanks !
I'v the same problem, in the begining it was ok but later came this problem witch make me think an other app caused it, stil have the problem and no solution sorry, if you solfed it please let me know.
keesvl55 wrote:I'v the same problem, in the begining it was ok but later came this problem witch make me think an other app caused it, stil have the problem and no solution sorry, if you solfed it please let me know.
Sorry.. Havent had any luck so far.. Have still been waiting to find a fix..
