My 6260 shuts down directly after pressing on-button. Screen goes white for a second or two, then shuts down. Anybody had this problem before and what happend after? Battery is fresh. Tried without mmc and sim inside, same problem.
6260 shuts down
well,do not worry much. It's the 'package' that come together when you bought the phone, 😃
Sorry, I don't understand...
I am presuming that you have charged the battery, if not charge it first, if you have then it might be a duff battery and in which case take it back to where you got and get them to give you a new phone and battery.
If you cannot take it back to the store, then I suggest you get a new battery. If that fails try a different charger, if that still doesn't help then the only thing left is the phone. Which you will then need to get replaced or repaired.
My_6260 wrote:Sorry, I don't understand...
a lot of 6260 users experienced the same thing.Maybe you can try reset your phone.
It turned out to be be the battery after all.
My_6260 wrote:It turned out to be be the battery after all.
really? 😃
but be prepared,you may experience the same problem in the future
