P900 flashed with P910 Firmware
4 replies · 8,038 views · Started 23 February 2005
Hi there , had a question , what does exactly mean "P900 flashed with P910 Firmware" , is that possible ? and what is going to change if i do that ? are the icons going to change ? is my P900 going to change into a p910 one (except the flip) ? is it a good choice ? am i going to be able to support more memory ? do you suggest me to do that "Delta747" 😉 ( or anyone else )?
Thanks In Advance 😊
Ps : what are the differences between P900 & P908 ??? in some sites i'v seen "P900 , P908 & P910"
Theoretically it IS possible. You'll get the latest OS with small upgrades (compared to the P900), the only major difference is that your P900 will accept the Duo PRO cards (so memory cards upto 1gb instead of 128mb). However, I've heard bluetooth doesn't work properly after the upgrade. Personally, I wouldn't take the risk.
P.S. it's Delta737 😉
And is there a way to "Down"Grade from P910 Firmware back to a P900 one ?
( if i don't like it ! 😉 )
