connot open .jar files on 7610 .pls help.
3 replies · 9,128 views · Started 24 February 2005
hiiii everybody i cannot open .jar files on my 7610 everytime i go to install .jar file on my 7610 it says file corrupted an cnacels the installation automatically, so plss help on what can i do and one more question does anybody know why call cheater does not work on 7610 or if anybody has a version of call cheater that works on 7610 pls can anybody give me. thanx a million.
Well, I think that problem is in missing *.jad file, but I'm not sure. Apparently you should copy both files in to your install directory, and it should work. I have a call cheater that works n my 6670, and if you send me your mail, i will forward it to you 😉
I too am having the exact same problem with my nokia 6670. I am trying to install a sample program from the Symbian Series60 SDK version 7.0 (which is listed as the proper version for this phone). After generating my sis file, I used the Nokia application installer that came with the phone. It successfully downlaods the file and attempts to install. the phone displays:
"Application is untrusted and may have problems. Install only ifyou trust provider." ::I click yes::
"Install travis_hello?" ::I click yes::
"pplication my not be compatibel with phone. Quit isntallation?" :: I click no::
after asking to specify which memory I want to use it displays:
"File Corrupted" and the exits the installation process.
Am I not setting up something in the phone? The two files that I inlcuded in my package file for generating the sis file is the *.rsc file and *.app file. Any ideas?
Thanks,
Travis
'Corrupt' means here that u don't have the file with full size. Some file has missing. U must d/l or get the new one 😊
