N6600 MMC maximium size?
4 replies · 2,714 views · Started 24 February 2005
Hi Guys,
I was just wondering i have a nokia 6600 and i was wonderinng what is the maximium MMC card can it hold? And How much percent are you sure.
Thx Artin
Artin wrote:Hi Guys,
Thx Artin
Well Im try up to giga without any problems or noticable slow down in performance...
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
Hello 😊
I am using a NCP branded 1GB MMC in mine 6600. No problems whatsoever, the card is fast in response, all apps installed on it run perfect and Phillips Camcoder does record WITH sound when using that card.
The usable memory is 980 megabytes.
Kind regards.....
your Thanh
[QUOTE=Artin]Hi Guys,
Thx Artin[/its 1gb as far as i know.but its slow .i rather recommend 2 use 512
Hello 😊
See my above post... it's (the 6600) DEFINITELY able to use 1-Gigabyte MMC's since i use one since a while and have no problems whatsoever.
Kind regards....
your Thanh
