y cant install IrRemote?
2 replies · 3,281 views · Started 24 February 2005
i had install a v1.36 irremote to my N6260, but when i delete it with Fexplorer and try to install the version 1.41, it said file corrupted....
pls can anyone tell me which version of FScaller and Call Cheater is for N6260?
y this phone cant use so much s60 software? of only me hv this problem? can anyone tell me any software 2 change the size of walpaper become (176 x 208) to fit the screen?
[QUOTE=wylun]i had install a v1.36 irremote to my N6260, but when i delete it with Fexplorer and try to install the version 1.41, it said file corrupted....
y this phone cant use so much s60 software? of only me hv this problem? can anyone tell me any software 2 change the size of walpaper become (176 x 208) to fit the screen?[/QUOTE
if you want to remove any unwanted application,always use application manager.Not by deleting yourself because you may delete the wrong files.Only after you've remove the application using application manager you can delete the leftover files.But make sure it safe first.
in the moment,fscaller is NOT working on 6260 and btw,i am using call cheater version 1.00.
you don't have to change the size of the image,just save it to gallery,open it and choose the option to use as wallpaper, 😊
i installed "PsiNT.irRemote.TV.v1.10.S60.SymbianOS6" this program didn't seem to work . i dont know if i'm missing anything, if any1 has better versions or same trouble pls reply.
