tomtom mobile probs
1 replies · 1,806 views · Started 24 February 2005
i have just recently purchased tomtom mobil for the nokia 6600 but i cannot get the .exe program files to work so that i can run the software
has any body out there got any ideas
archie355 wrote:i have just recently purchased tomtom mobil for the nokia 6600 but i cannot get the .exe program files to work so that i can run the software
There will be some files in the tomtom directory on the MMC. You need to make sure that these files are not read only, if they are then you need to remove the read only property.
You can do this either two ways, either get a program that is a file explorer for you phone (www.gosymbian.com - File Explorer). Or if you have a mmc card reader you can use that to remove the read only.
Hope this helps
Diasmj
