9210i needs a jump start
4 replies · 2,176 views · Started 25 October 2002
Whilst using my 9210i, it sometimes just dies, the phone/ communicator screens just turn blank, after leaving the phone switched off for a while makes no difference.
The 9210i has to be plugged into a charger to sort of jump start it!
Has this happened to anyone else?
Its is a great inconvenience when you have no charger! But thanks to the many Carphone Warehouse Stores in Central london who are more than happy to provide a jump start!
Same problem occured with the 9210, thought they may have fixed that. Easy solution is to short all the battery connecters in the 9210(i) with a coin or other metal object and then put the battery back in and it should come back to life.
What SwitchBlade said - just tap the battery connectors on the phone with a coin and the phone should be able to power up. Oh, if you can get Netmonitor running on your phone, could you check out test 35 right after you get the phone to reboot? It's supposed to tell you the reason for the last reset, but doesn't in my phone...
Hmmm....I expected Nokia to have fixed that 'little' problem by now. Looks like you can't ask for too much, eh? 😞
BTW, if you don't mind me asking, are you also a member of the M5 forums? If you are, you have excellent taste in cars! 😃
FAO. AAY
Thanks for the advice, and what M5 forum is this?
Is some using my net name? :evil: :evil: :evil: :evil:
Let me know
[quote="4u2nv"]FAO. AAY
Let me know[/quote]
Hmmm....after some lurking at the forums at www.BmwM5.com, I noticed a member there with the same net name as yourself, also from London...of course, I could be all wrong and maybe you don't have a GT2 😃
