Is it generally possible to synchronise contacts and calendar entries with my corporate ms exchange server? I tried to add a configuration profile using connection type "internet" and our exchange server as host adress. All i get is a error log, saying "Synchronisation was interrupted before any data was sent to the server". do i need any kind of special configuration or add-on on the server side?
and what is this about if the 9500 is able to remote-sync with an exchange server:
http://www.allaboutsymbian.com/news.php?id=34174
Direct phone network based (so called over-the-air or OTA) synchronization with a Microsoft Exchange server using a Symbian based phone like the 9500 is possible only and only if you also have set up a so called "SyncML Server" that has been configured to talk with the Exhance server.
Such "SyncML Server" products are sold by companies such as FusionOne, Starfish!, Extended Systems, etc. There's a list of such here:
http://www.openmobilealliance.com/tech/affiliates/syncml/syncml_compliant_products_missing%20files.html
Microsoft Exchange 2003 has built-in OTA synchronization capabilities (one form of ActiveSync, which also in Microsoft terminology refers to a separate and different phone/PDA-directly-to-PC sync application), but it is a Microsoft proprietary solution.
The article you point to only says that Nokia's Enterprise Solutions organization has reached an agreement with Microsoft to license this server-based ActiveSync version.
Persumably this means that at some point in the future devices from Nokia may or may not be able to use that technology. It also may or may not mean that software will be made for old devices which don't have such capability today (like the 9500).
In other words, if you want to do it today, you need to (or whomever runs your Exchange servers needs to) buy a SyncML Server from somebody.
Otherwise you're limite to synchronizing locally (USB, Bluetooth or infrared) with your desktop PC and Outlook on it (which, of course, indirectly is synchronizing with the Exchange server somewhere).
We are using IBM websphere. It depends on what is set up at your company
N/A wrote: if you also have set up a so called "SyncML Server" that has been configured to talk with the Exhance server.
thank you for the info. i�m not sure, if i�ll get my admins to do this. do you have any idea, if that server could run on a different domain?
N/A wrote:Otherwise you're limite to synchronizing locally (USB, Bluetooth or infrared) with your desktop PC and Outlook on it (which, of course, indirectly is synchronizing with the Exchange server somewhere).
i have a mac!
