Hi
Has anyone got one of these for your 6630?
If so where did you buy and how well does it work?
Dual Sim Card Holders
ka6r9en wrote: ... Has anyone got one of these for your 6630? ...
And what is one?
a dual sim card holder
i have one for my 2100.. it sticks to the back of the batter and has place for two sims while there is a ribbon that leads to a third sim (which is a fake one) and is inserted in the original SIM slot, well since the 2100 is quick its easy to switch on and off and thus swap lines.. dont know if it will fit in the 6630 and how well it will work..
ka6r9en wrote:Hi
I used the ghost dual sim, it works on my 7210,7250,3650,6620. But not on the 6630, don't understanded.
