Greetings!
I own a N7710 V 03.04.02 / 25-01-05. All the software that I install, I cannot find a way to execute it. According to Nokia, after the install, an Icon should appear on the desk. In my case, it doesn't! This is really annoyng. Has anyone experienced this?
Please feel free to ask any questions about my FW release.
Regards,
PJ
What software have you installed, exactly? Were those applications intended for the 7710 and not some other (Symbian OS based) phone?
N/A wrote:What software have you installed, exactly? Were those applications intended for the 7710 and not some other (Symbian OS based) phone?
Greetings!
One of the them was Soccer 2004 v1.0.1, downloaded from Nokia on the Nokia 7710 area.
slasher wrote:Greetings!
Hi guys....
I just purchased my Nokia 7710, I have 1 GB MMC for storing & me too find a similar problem.. As i downloaded application from Nokia site (.SIS) files. when i try to install thru Application Manager it install successfully.. But no shortcut is created on the desk nor I can execute the application.. Could anyone please tell me what to do.. how to run them... when I open Appl. Manager it displays a list of application which I have installed. but unable to execute...
kindly let me know... As I desparately need it...
Thanks..
Ahmed
what is the latest software that you have loaded onto
the 7710?
iffu2004 wrote:Hi guys....I just purchased my Nokia 7710, I have 1 GB MMC for storing & me too find a similar problem.. As i downloaded application from Nokia site (.SIS) files. when i try to install thru Application Manager it install successfully.. But no shortcut is created on the desk nor I can execute the application.. Could anyone please tell me what to do.. how to run them... when I open Appl. Manager it displays a list of application which I have installed. but unable to execute...
Thanks..
Ahmed
Greetings!
I've sorted out the problem with some help. What I've done was to 'soft' reset the phone using the code *#7780#. What you loose is the phone settings. Nothing else! After reboot the icons are on the desk!
Can you please let me know if your 1Gb card works fine? Nokia says the maximum capacity is 512Mb!
Thanks!
Rehgards,
PJ
The Software for Nokia 7710 which i am using are Switcher, Smart Movie,Mobi Reader, Stacker(For 9500Demo), Anti Virus, Acrobat Reader(For 9XXX) Screen Capture and Orignal Game
could you give me a run down of Switcher, Mobi Reader, Stacker,
and their functions on the 7710. thanks
Vicky wrote:The Software for Nokia 7710 which i am using are Switcher, Smart Movie,Mobi Reader, Stacker(For 9500Demo), Anti Virus, Acrobat Reader(For 9XXX) Screen Capture and Orignal Game
Hi...i'm new here...i just got a nokia 7710...where can i get all those softwares from...please...i've lost all hope for this fone...no themes...no applications...nothing....can't find anything for my 7710...help!!
Hi guys Nokia has released a new software release to upgrade 7710s with old software which will stop hanging/crashing problems go to local service centre for free upgrade.
