Offline mode 6670
6 replies · 3,542 views · Started 25 February 2005
Is there any "offline" mode profile that disable the telephone prog like what 6630 have? If have can tell me what prog support that
symbian 8 has offline profile built-in so the 6630 has it. u can use third party software like psiloc system tools to go into flight mode on ur 6670
zainman wrote:how can that be? email psiloc about it.. make sure u arent using a crack..
No for their website. Install it say expired. Can't even try to see whether it work.
i tried psiloc on my 6670 and it didnt work. when i activated it, it said that the phone will turn off and that i have to remove sim card, and then turn phone back on. but it didnt work, the phone asked me to insert the sim card. although, if it had worked, that would be so annoying have to turn off the phone and take the sim out.....not worth it..
I Have written to Psiloc about the System Tools app not working on 6670. They said they will come up with an updated version. I am not sure if they have done it.
