How to turn on the backlight to always on instead of switching off after 15 secs?
Backlight Always On
use Fexplorer, options>tools>turn light ON
Is there any apps that can use a short cut key to activate/deactivate backlight
i dont think so.
get this app been useing it on 3650 an now 7610 work great
Torch
Thks. Try it out first.
No the one I want. This is to blank out the screen & on all the time
What I want is to able to turn on/off backlight while using phone like what Fexplorer does. But Fexplorer got no short cut keys.
with Torch can set key for it got 6 keys use
RCNOKIA wrote:with Torch can set key for it got 6 keys use
How? When I get to torch, it show me a blank white screen.
May be not compatible with my 6670.
That's what Torch does: displays a completely blank, white screen by default (for the phone to be used as a flashlight/torch). When it is on, you can leave it running in the background by using the menu key to switch to some other application (and the backlight will stay on).
Same with the FExplorer option to turn backlight on (but FExplorer does also a lot of other things, whereas Torch is a single-purpose utility app).
N/A wrote:That's what Torch does: displays a completely blank, white screen by default (for the phone to be used as a flashlight/torch). When it is on, you can leave it running in the background by using the menu key to switch to some other application (and the backlight will stay on).Same with the FExplorer option to turn backlight on (but FExplorer does also a lot of other things, whereas Torch is a single-purpose utility app).
So how to set the shortcut key to turn off/on it.
I think there is an app call PowerTorch that comes with shortcut key
