Hello
I've got a problem with my sx1:
when I load bettery in my phone, it displays an information "system error" it doesn't turn on.
what I can do with this problem?
thanks
Sx1 battery problem
Michalgal wrote:Hello
thanks
At First STEP try to Reset your Phone :
Pressing "#" & "*" & Turnon Keys to power on phone.
(I recommend to do it two times.I have this problem when i install MSDriveE &
Problem Solved after 2 Times Phone Reset.)
if Problem doesn't solve,Try to upgrading your firmware to V15 after reseting phone.
Good Luck
Thanks ! It really works !
Thank you very much you saved my life .
