I just tried several hours to get any connection with my 9300 thru the Laptop via Infrared.
I have made these connections with any Sony, Ericsson and Siemens Mobile Phones with no problems.
But I have big problems with the Nokia 6230 and 9300: First I install the IRDA-Drivers and this is not the problem - installations is done with noi errors on Com Port 4
But it is not possible to get a connection thru the Internet (ERROR: Modem is not responding) and when I test the installed modem at the Modem/System Control the same error window appears.
Has anyone installed the modem driver succesfully to acces the Internet via CSD or GPRS? If yes, it would be great if you can write down the exact way to handle this.
Thanks a lot,
and sorry for my bad English (I am from Germany)
Bye
Klaus
Ok, this might sound stupid, but did you enable the Modem on your 9300 (there is a special program for it pre-installed in the Tools folder)
Delta737 wrote:Ok, this might sound stupid, but did you enable the Modem on your 9300 (there is a special program for it pre-installed in the Tools folder)
no - it don�t sounds stupid. I am a really idiot.
I have activated the InfraRed Communicatiion with the IR-Keypad (same when I make my Syncs with the Nokia Suite) and I have never seen the Modem Activation File in the Tools folder. So it seems that their are two different comunication protocols: one for Modem Connections and one for PC File Connections.
However, everything, incl. GPRS, is now working with the IRDA-Port of my Laptop -
many thanks to you,
Bye
Klaus
By the way: Bluetooth Connections are still not working - the pairing between the 9300 with my PC is not the problem - but I can�t get a Modem oder PC File Connection (Bluetooth is not available at the Nokia Connection Manager - only Cable and IRDA). I think that is a problem of my Bluetooth Stick from the Germany Company AVM - I think they use an own Protocol which is not compatible to the WinXP-Nokia PC Suite Combination
well first u have to enable modem in the
Tools>> Modem and then activate
not from the shortcut key on the keyboard...
secondly i have also been trying to use my GPRS connection of the phone to work on my pc dosent work i have tried bluetooth and cable ...
firstly u have to install the driver ... when u connect through cable it will detect automatcilly .. it installs fine when i conect it enables the modem on the phone andc then after a long time it says connection time out ...
in the bluetooth u have to add the modem and then seclect from the list do not let it search ... it installs on my pc but it uses com1 and if i try to connect it says modem not available ... can i cnage the com port it dosent give me any option on the driver installation
and after that .. i dono .. it dosent seem o work .. this is how far i have reached ... if anyone knows after that please help
bilal_sheikh wrote:firstly u have to install the driver ... when u connect through cable it will detect automatcilly .. it installs fine when i conect it enables the modem on the phone andc then after a long time it says connection time out ...
This was happening on mine as well but its now working on both cable and Bluetooth. It says connection time out because it cant find the access point to use. When dialling, use the number *99# and in the Modem Options in Control Panel on PC, type in your access point e.g. (payandgo.o2.co.uk) It should start connecting to GPRS
Usually this gives an error when u try dialling. It used to connect for 1second & then dis-connect??? right???
This is what i did.. i went to Phone & Modem settings in control panel & went properties of the Nokia 9500 BT Modem. Then i went to the advanced tab & put the following in the extra initializing commands....
AT+CGDCONT=1,"IP","www"
Now my Nokia 9500 works as a modem via BT. i'm sure this will work thru IR & Cable as well.
Instead of " www " you can put ur own GRPS ACCESS POINT NAME
HyPeR,
Interested in your suggestion, however, I don't have "Phone & Modem settings" in my Control Panel.
