i want to update my spanish(telefonica) sendoX and the usb conect in normal mode works fine...but in engeneer-mode the driver (windows xp) does not work...
dont tell me to desactivate firewall and stuff.. i did everything.. i think that on the new sendo page are not the correct drivers. i think they should have different drivers for normal and engeneer-mode because of different usb_ID.or am i wrong..
i dont have the wrong firmware-update!!! i am not even that far!!! the pc is not seeing the phone at all..
does anybody know how to update by sd_card.. i dont find the software anymore (telefontreff.de) no files on the ftp anymore...
thanks for any help
basti
driver_problem 4 firmware-update
It does require a different USB driver - the one for update mode is in the C:\SendoUpdate folder created when you downloaded and extracted the firmware update.
thank you.. but i had a problem with this driver. the pc is just "half" detecting the phone in the update-mode. it aperars, disaperas, apears, disapears... and so on in a one second rythm. no problems at all in the normal mode...
any idea?
thanks alot.. i installed everything again at now its connecting... :icon14:
