:icon4: my nokia 3650 will onli type in numbers and not let me type words, I have been thru all da settings, an tryd pressing the hash key, but that jst typs a hash & dusnt chang anything. it also brings up an error message for every program that I open, but then the program runs fine. can anyone help, or anyone had the same problem?
3650 Txtin In Numbers
ratboi wrote::icon4: my nokia 3650 will onli type in numbers and not let me type words, I have been thru all da settings, an tryd pressing the hash key, but that jst typs a hash & dusnt chang anything. it also brings up an error message for every program that I open, but then the program runs fine. can anyone help, or anyone had the same problem?
There is a quite simple solution 4 u, all u need to do is follow few simple steps from below link...
Alphabeth input problem fix (4 sin_preacher)
Hope this help
Cheers
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
thanks bt i cnt register, could you pls copy the steps, or does anyone no of nay other place that could give me these steps?
sorted it, thanks for your help!
ratboi wrote:sorted it, thanks for your help!
Glad to hear that 😉
What about registration!?
It is so simple, in two single steps... 🙄
Cheers
Remove the MMC, Reset your phone dude pres *#7370# in standby mode, but backup your contacts first before you do this...
Did you press the Hash key (as in just press once) or did you press and hold (i.e. depress it for a long time) ?
Tee Horng Hean
www.freesoftware.com.my
I founded solutionon on one website here is for future requests:
Problem With Alphabeth Input
*** IMPORTANT ***
Quite a lot of people are complaining that they suddenly can't type any alphabets.
No matter how hard they press the "ABC" button, the alphabet mode just won't
appear. This is apparently a known issue after you have installed wildskin.
To fix this problem, please uninstall Wildskin then follow the steps below.
Step 1.
Open any file explorer program (e.g: FExplorer, SeleQ, etc.)
Screenshots shown are using FExplorer.
Step 2.
Browse to C: drive.
Useful information:
C: is Flash
D: is RAM
E: is Disk (MMC)
Z: is ROM
Step 3.
Browse to system directory/folder.
Step 4.
Highlight the System.ini file
Step 5.
Press Options and select File
Step 6.
Choose Delete from the menu
Step 7.
A confirmation will ask if you are really sure to delete this file. Don't be afraid, just choose Yes (shown as Oui here -French version- ^_^).
Restart your phone by switching it off and on again. The system.ini will be automatically generated again and you would be able to input any alphabet again ^_^
*special thanks to YaouanK
