I would like to know that according to u ppl which is the best phone among nokia 6670 and nokia 7610. I will be using the phone for applications and entertainment purposes and not for office use. As i am a college going guy so my main point is entertainment and creativity
Plus i would like to know that the office documents that can be viewed on 6670 can they also be viewed on 7610
I would also know that does the nokia 7610 support 512 MB rs-mmc and if yes which brand would u suggest me and what is this dual voltage rs-mmc and is it supported by nokia 7610 and nokia 6670
And lastly plz provide me with some links that i can download via internet (not gprs / wap) free softwaers (applications & games) for symbain phones
Thank You
They are the same phone, with different keypad and slightly different set of applications (apps missing one one, you can get for the other separately). So, pick the one that looks better in your eyes.
Well Nokia 6670 and Nokia 7610 are almost same
if u want Business Look Go for 6670
If u want Cool, Fashion Look Go for 7610.
As you are student go for 7610 and abt the Office Programs You can download from nokia site.
and i personally have used Microsim 512 Rs MMC
and now using 256 MB
and it support both Voltage MMC
and abt the 3rd party application there are more then 100 freeware software
and other software which paid are also avaible at nominal charge from 5 to 15 dollor(Approx)
and more then 1000 themes on symbianthemes.
I had two 7610s but got frustrated by the voicedialling which never worked. Subsequently got a 6670. This phone is too thick, but the voicedialling does at least work.
Quality of both is the same. See which one fits better in your hand and to your eyes.
Not being able to change the font size is the biggest pain.
I have had both. Gave up my 7610 for a 6670 because I thought it would offer more. I was dead wrong. I loved my 7610 and I wish I had it back. the 7610 is just the same with a boaring style...anyone want to trade???: :tongue:
