Profile changing with left or right idle softkey - How can I do it?
9 replies · 3,395 views · Started 27 February 2005
Hi All!
I need this function (Profile changing with left or right idle softkey), but I haven't found it on my 6670.
With voice control can do it, so it should be a solution for it.
If it is possible with the standard phone soft it could be great, but if just with a software, it will be good for me, too.
Please help me!
Is not using the power key for changing profiles enough (or haven't you discovered this feature yet)?
That is, a short press of the power key will display the profile list. Another short press will move to the next profile. Once you have the profile you want highlighted, a long press will activate it.
N/A wrote:Is not using the power key for changing profiles enough (or haven't you discovered this feature yet)?
Yes I know his feature but I want another one.
It's not to easy press the power key..
And this solution the same if I attach the profile selector to the right key and after I choose the profile.
I need that I can attach the "Silent" or "General" profil to the right softkey, and pressing this button will change the profile to "Silent" or "General". (With just 1 press)
Actually you can NOT do it with one button but with two (or few) clicks ....
It goes like this :
Settings -> Phone -> StandBy Mode -> Left(Right) Selection Key -> Profiles
And that shold do the job.
yuhackman wrote:By my best (modest) knowledge, no :frown:
OK, thanks!
But so good would be....
Why not try a voice command? That's what I do ...
And I also, I changed the Left Selection Key to "Profiles", and the Right as "Camera" ...
If you happen to have a 6630, then there is a built-in shortcut to switch between the General and Silent profiles: long press of the '#' key in standby state.
