Why is the earpiece volume is soooo LOW???
1 replies · 8,270 views · Started 01 March 2005
Everytime I use this phone I end up having to use the loudspeaker which is so annoying. The earpiece is very clear but even with the volume all the way up the sound comes and goes....one minute it will be audible the next I can barely hear anything. Am I the only with this problem?
nechronics wrote:Everytime I use this phone I end up having to use the loudspeaker which is so annoying. The earpiece is very clear but even with the volume all the way up the sound comes and goes....one minute it will be audible the next I can barely hear anything. Am I the only with this problem?
I have noticed the same issue, I believe it deals more with where your ear is located on the back edge of the 7710 and even then it has a low volume. I turned down the loud speaker and turn over the 7710 to listen, don't worry the mice still picks up your voice and at the same time the screen doesn�t get smudged. I'm more on "www.expansys.com/forum". I get a fairly quick response there on issues.
