"Phone Startup Failure. Contact Retailer"
3 replies · 2,294 views · Started 02 March 2005
Arrrrggggghhhhhhh 😮 😮 😮
I am already on my second 6630 from Orange UK and have had no problems in the past 6 weeks.
Yesterday morning I found a the message on screen as listed above!!! Whats that about? anyone else had.
The biggest kick in the b0ll0ck$ is that Orange tell me I am lying and that it is impossible that I would get that message.
It has since happend a further 4 times and am also getting loads of random reboots.
This even kicked me off mid call and showed the above message?
Any one else???? 😡
Wirelessly posted (NOKIA 6630: Nokia7250I/1.0 (4.22) Profile/MIDP-1.0 Configuration/CLDC-1.0)
f-t-b wrote:Arrrrggggghhhhhhh 😮 😮 😮
Any one else???? 😡
Demand a new handset! If orange say they dnt believe u then take it to a orange shop and show it to them! Orange shud know that s60s sumtimes fail to boot! After showing the orange shop ur prob id shove the fone up there ass!
yeah i had that when i changed my memory card, something must of got corrupted i formatted the phone (holding the keys when switching on) and its been ok ever since.
Charge your battery to full and
Try the step's below !!
Full phone format on a Series-60 device
If any of the problems listed below is happening to your phone:
A. Blank screen phone unable to boot-up.
B. Phone is only able to boot-up to "Nokia" screen (may flash "Nokia" 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive.
--- WARNING: This will ERASE EVERYTHING on your phone ---
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
Do not let go the three keys until you see the "formatting" screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
