My Motorola A1000 Crash.!! Help
10 replies · 8,598 views · Started 02 March 2005
I recently bought a motorola A1000 and i try to install some of the p900 software into my motorola a1000 (as i know the OS in P900 is same as A1000) and when i start using the software or even after the software is install...the phone suddenly restard and get stuck in the start up screen (Motorola 3G)...can anyone pls help me??? pls...
freestyler0708 wrote:I recently bought a motorola A1000 and i try to install some of the p900 software into my motorola a1000 (as i know the OS in P900 is same as A1000) and when i start using the software or even after the software is install...the phone suddenly restard and get stuck in the start up screen (Motorola 3G)...can anyone pls help me??? pls...
Ciao, can samebody help me?
When i turn off my Motorola a1000 and then i turn on it again, it stop on Motorola 3G.
Sorry for my language i'm italian. [email][email protected][/email]
D@nte wrote:Ciao, can samebody help me?
Ciao D@nte,
ho lo stesso identico problema sul mio! Che stress! 😡 Sei riuscito a trovare qualche dritta?
Ho provato a tenerlo spento una notte intera senza batteria, ad accenderlo senza usim, a caricarlo...
Avevo trovato un topic su un forum italiano ma � stato spostato chiss� dove!?!
Se hai notizie a proposito avresti voglia di postarle? Se riesco a trovare qualcosa prima faro lo stesso.
Grazie e ciao! :icon14:
hi !
my fone is mototrola a100 get stuck in the start up screen too, can u help me please??????????? pls
my fone is motorola a 100 the same eror
my fone notive board:
PROGRAM STARTUP
REASON CODE KERN-EXEC
REASON NUMBER 3
CAN ANYONE HELP ME ???/ PLEASE PLEASE
Sorry , my english is not good.
I hope that you understand i want tranfer you
to starup mobile , you can operate follow :
1. Release External TFlash out of Phone.
2. Then drop & down keypower to start mobile.
3. if the mobile is OK , you must be Master reset phone (lock code : 0000)
Good luck to you
I dont know my master reset code and 0000 is not working! What can i do please help..........
Thanks,
Ashish
