To solve comm problems between Nokia 9500 and MS Outlook:
Analysis: The problem is caused by a corrupted Agenda file.
Solution:
-Enable in Office, File Manager, MENU Tools, Settings: Show system directory > Yes
-Go to Calendar, MENU File, More Options, Save as: save the calendar file under a different name, and exit/close the Calendar Application
-Go to Office, File Manager, Communicator\System\Data to the Calendar file, and delete the file. BE SURE THAT ALL YOUR CALANDAR DATA ARE IN THE MS OUTLOOK CALANDAR
-Go to Tools, Synch, MENU, Tools, Reset PC Suite profile.
-Remove battery and restart 9500
Esthablich connection between PC and 9500 and do the synchronisation from the PC
Peter
