Hi, im a little confused as ive been told for the NOKIA 6630 it takes mmc cards or dv rs mmc cards !!! which is correct and whats the highest capacity card and diference between them etc ? thankyou..
nokia 6630 which cards are correct ?
The 6630 only takes dual-voltage (or DV) type RS-MMC (Reduced Size - MultiMedia Card) cards. Sometimes also labeled "MMCmobile". No other kind of cards work. The highest capacity card that works is whatever is the biggest on sale.
N/A wrote:The 6630 only takes dual-voltage (or DV) type RS-MMC (Reduced Size - MultiMedia Card) cards. Sometimes also labeled "MMCmobile". No other kind of cards work. The highest capacity card that works is whatever is the biggest on sale.
128mb maximum. 256mb due to be released 16th March but DV RS-MMC costs about 8 times as much as normal MMC I have worked out!
mike_freegan wrote:128mb maximum. 256mb due to be released 16th March but DV RS-MMC costs about 8 times as much as normal MMC I have worked out!
many thanx for your quick reply to my question..just as i thought will wait for the 256 dual voltage card
How much does 128mb costs?
Animation wrote:How much does 128mb costs?
If you search REALLY hard you can pick one up for about �25 of ebay. Make sure it is Dual Voltage before you bid.
-Mike
