:cry: Can i use webviewer if i connect my 7650 to the internet using a WAP connection Or do i need a GPRS. I mean how the heck do i connect my 7650 to the internet so that i can use webviewer to see the html sites. Plz help me .PLZZZZZ
Plz help me with webviewer
Deepak,
You don't have to use a GPRS connection.
take a note of your main access point's Gateway IP address, change it to 0.0.0.0 then try webviewer through this access point, if it works fine create a new access point with all the same details as before, use this only for your webviewer.
remember to add the gateway back into the original access point.
Cheers,
Tsu
