Dictionary word information missing. install word database
4 replies · 59,730 views · Started 03 March 2005
i use a new 7610,, when i just use the dictionary,, it show this " Dictionary word information missing. install word database" ,, any help for this???
Dictionary, i'm missing Word Database... Does anyone know the steps too install?
If you are talking about the english-chinese dictionary database missing follow these steps.
Download the English-Simplified Chinese Vocabulary Set from the nokia 3520 phone support page at the nokia website.
set your phone on USB mass storage mode and extract the downloaded files to the private folder of your phone's memory card.
Quote:
From your computer, double-click on [My Computer] and open the [Memory card name] Removable Disk Drive.
Unzip and copy all the files with sub-folders to "\\[Memory card name]\private" folder in your memory card.
This works for n95 model phones also.
I'm using N95 now. My dictionary also need install dictionary word database. I've and try your way but still can't. why??
I have an n78 but I installed this n95 dictionary database and it works fine.
http://www.nokia-asia.com/A4812001
I had to use Drakkarious' CapsOff and X-Plore to get it to copy to the "Private" folder on my memory card though. Then use CapsOn after moving or copying the folder. Once the "101f9cfe" folder is in the "Private" folder on your memory card, the dictionary should work.
Took me FOREVER to get this working!! :tongue: :frown: Thank the Lord that it's installed and working. Hope this helps.
Swaine77
