Why is some file locked
3 replies · 1,799 views · Started 03 March 2005
Can someone help me.... why is it that some file get locked and u cant send them such as ring tones and some java games pls help
its all to do with the later firmware releases and something called digital rights management (DRM). basically, if the phone sees the file as something not created by yourself it will not let it be sent to others. this software is designed to help stop the spread of warez etc. i was lucky enough to have a very early 6600 with 3.42.1 firmware which had no DRM controls on it so i could send anything i wanted :tongue: but my new (ish) 6260 has the DRM screw tightened right down :frown:
Is there a why to to get red of this file?
My previous 9500 was ok then the dealer had to change my phone coz i had problems and with this one i cant send anything pls help
no, the DRM controls are built into the firmware and cannot be removed. there have been various ways to try and get round the problem though. one is to rename the file extention to something like *.txt and then send. another way is to try mobiluck which is a free bluetooth application. there is no version avalable for the 9500, but you may be (extremely) lucky to get a version to work. some people have reported that mobiluck manages to bypass the earlier DRM controls. however newer firmware versions (certainly on 6600/7610 etc) cannot be bypassed - yet!
