help with deleting .wav file!!!!
2 replies · 1,171 views · Started 03 March 2005
Using pc-connect I have unintentionally copied a .wav file in the playlist directory of my sendo. Now that file is not showed by the phone and using the file browser of pc connect I can't delete it but only rename. Does anyone know if there is another way to delete files on my sendo?
Please help, thanks.
You have probably saved into a system folder which prevents deletion of content via PC connect browser. Try installing a 3rd party file explorer on the phone and then locate and delete. FE Explorer is OK and there are others on this site under the software tab!
thanks for the help. I dowloaded a FE program and I succeded to cancel the file!
