Nokia 6260 help!!!!
3 replies · 2,064 views · Started 03 March 2005
Can someone please tell me how to turn the volume of the alarm clock in the phone up??? Its soo soft right now, i cant even wake up for work!! Please let me know.. appreciate your help..
Thanks,
Stallion :frown:
i think the clock alert volume is dependent on the ringer volume set by the profile in use. if you have a "bed time" profile with a quiter ringtone, then all the alerts bcome quiter. try using a higher volume on the profile. mine wakes me up without fail.
dansansome wrote:i think the clock alert volume is dependent on the ringer volume set by the profile in use. if you have a "bed time" profile with a quiter ringtone, then all the alerts bcome quiter. try using a higher volume on the profile. mine wakes me up without fail.
That is correct!
This phone really doesn't offer much in the way of volume control does it? Only the one volume setting for ringing, messages, alerts, alarm clock, etc... Doesn't allow for much flexibility...
