Hi, I'm new with N-gage. I installed a eBook reader(ReadM), and I downloaded several ebooks from memoware.com. The problem is, that i don't know where to copy them, for the ebook reader to find them. I tryied in different places like the root directory of the mmc, or the ReadM's directory, but no result :frown:.
P.S.: The book are in .pdb format.
Help pls:How do i read eBooks on N-gage?
I think there's a seeting in ReadM which lets you say where it should scan for ebooks. Might be worth checking that out?
Rafe wrote:I think there's a seeting in ReadM which lets you say where it should scan for ebooks. Might be worth checking that out?
well i did that, i checked all the boxes where to scan, but still nothing. I heard that are different ebooks formats, every format being specially optimized for a readere, eg.:isilo. isilo3, .doc, tomraider. and pdf(adobe) - this is what i found on memoware, those .pdb's i downloaded could only be read by isilo. I checked most of those readers, but there are no versions for symbian. I'm pretty confused...
Maybe you should try Mobipocket Reader (www.mobipocket.com)
