Hi All,
This is my first time to post on the forum but I've been looking for it for quiet a while. I just got my new communicator, everything is fine, but I'm facing two problems, I hope anyone could help.
1- I have windows XP but it seems that I can't synchronise through IR only through the data cable, but some people outthere said that they can synchronise through IR on windows XP. How can I do this.
2- I downlaoded the Bounce level pack 2 and I installed it, everytime I finish the 12 first level it tells me that you need to download extra levels from the Internet if you want to, but I'm sure that level pack 2 is installed because it's there in the Install/Remove icon, I tried to uninstall it and then reinstall but nothing, I tried to uninstall Bounce and install it and then played from the begining and then when I finished still nothing there..
I would appreciate if anyone could tell me what's going on.
Thanks a lot for your help.
