Please help......am not able to open Manager to uninstall files
6 replies · 2,903 views · Started 03 March 2005
Please help....whenever i open Manager from tools folder...it gives an error saying App.Closed appmngr...........what to do..........help please
tomg wrote:Please help....whenever i open Manager from tools folder...it gives an error saying App.Closed appmngr...........what to do..........help please
try restart your phone 1st and try again.if still cannot,remove the first boot data
this happend to a friend of mines 6600, i replaced the App manager files in Z ROM driver with another 6600s ROM files and rebooted and voila! it worked!
NOTE: please only touch the Z driver on your own risk! and i only replaced the contents of the App manager file!
qhe_pit wrote:try restart your phone 1st and try again.if still cannot,remove the first boot data
after deleting the first boot data it worked...........thanks 😃
Any side effects in deleting "first boot data"? Was wondering, will the "first boot data" gets deleted if I perform a hard-reset (*#7370)?
DaViD_BRaNDoN wrote:Any side effects in deleting "first boot data"? Was wondering, will the "first boot data" gets deleted if I perform a hard-reset (*#7370)?
there are no side effects in deleting "first boot data"...........i don't know about the hard-reset.........but after deleting first boot data it really worked
zainman wrote:this happend to a friend of mines 6600, i replaced the App manager files in Z ROM driver with another 6600s ROM files and rebooted and voila! it worked!
how did you replace the files on the ROM?
