Help with PRETEC MMC 1Gb
2 replies · 1,911 views · Started 04 March 2005
Hi, guys.
Before buying my 9500, I had bought a MMC 1 Gb from PRETEC (or something similar). I thought it was very good.
The question:
Today for the first time I put the MMC in 9500 and all was without problems, MMC was recognizing and reading on the 9500.
Then I thought: " I am going to format it, as they say in many forums".
And I formartted it.
After half an hour of formatting, when it was taking 97 %, there went out a warning that say: "system: not valid Request " or something like that.
I've tried to format it more times, but always the same thing was happening: on having come to 96-98 % of the formatting, it was stopping. Now It was not recognizing the MMC.
Any idea, please??
Have you tried reformating it on a PC in a card reader, or any other device that can read it. I think the main reason for advice for formating is not to leave 92x0 applications on it that obviously won't work on the 9500.
Hi!
I also have a Pretec MMC 1gb.... had the same problems. My solution was:
Put in in an Pocket PC (ipaq, ...) and format it.
Then it worked.
Hope it helps - good luck
