512 Mb Rs-mmc
4 replies · 2,273 views · Started 04 March 2005
Hi does anyone over here using 7610 has tried out a 512 MB card or more capacity
Does the 7610 support 512 MB
And also does it support 1 GB
Plz do let me know at the earliest
Thanks in advance
Yes.
I'v tried just today, e.g. removed a 512 Mb MMC (Transcend) from my 6670 and put i the 7610, and all worked fine for me. 😊 Maybe it is becouse latest software version, so check it out. 🙄
I could not find any 1 GB RS MMC to test (buy) so I can not help you with this one :icon13:
Actually I have decided to buy a new 256MB RS-MMC card for my nokia 7610, but I don't know which one is compatible with my nokia 7610.
Any suggestion for me? (eg. kingston, apacer, etc)
Thanks ya 😊
Hi
I think the nokia 7610 suports all rs mmc (don't hold me to that), the one I'm using is a Muse Digital 256MB (x66 speed).
This seems to work perfectly and is not slow, I bougt this for about �22 of ebay inc p&p.
Hope it helps
