Sorry if this has been covered before, I did do a search but couldn't find a sure answer. My phone screwed up a while ago, the old too much memory phone freezes thing (woulda thought they could have fixed that by now, used to happen to my 7650 too). Anyway, if I start the phone up it boots to the normal screen eventually, but then I get a system error message, and then there's no chance of doing anything.
My question is, would there be a way of getting the phone useable again (if only just to delete some things to make room) so that I don't have to do a full format and get rid of all my saved images and stuff? Cause it would be crap to lose them.
If that's not possible, what is the best format to do? I see a lot of different ones about!
Thanks very much
badgerer wrote:Sorry if this has been covered before, I did do a search but couldn't find a sure answer. My phone screwed up a while ago, the old too much memory phone freezes thing (woulda thought they could have fixed that by now, used to happen to my 7650 too). Anyway, if I start the phone up it boots to the normal screen eventually, but then I get a system error message, and then there's no chance of doing anything.My question is, would there be a way of getting the phone useable again (if only just to delete some things to make room) so that I don't have to do a full format and get rid of all my saved images and stuff? Cause it would be crap to lose them.
Thanks very much
First of all u can try to pull out your MMC card and boot phone in safe mode, so u can make an backup before format..
If mentioned method dosent work all u can do is bootup three key format trick...
Hope this help
Cheers
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
